shadow passes: is it just me or is this a pain in the a&# ?
I’m not sure if it is just me, but I have no end of problems getting a decent shadow pass out of Vray. I haven’t used it in a while but I remember it being pretty easy in mental ray. Am I missing something? I have read the threads I could find, just hoping someone has an answer I couldn’t find.
VrayMatteShadow just renders like crap most of the time - artifacts and grainy and almost always useless to me or in need of heavy post manipulation. VrayShadow does not give me the actual shadow alone - it needs an alpha for the shadow only etc.
I just need a simple shadow pass that I just shows shadows that I can multiply into a shot. Any tips?
*EDIT* - I should say I am aware that I can render the object as matte, use the VrayShadow pass and combine that with the alpha, but then I have to render every lighting pass twice so I can have the shadow catching object rendered as well, or a proper alpha for the object casting shadows etc. It just seems very cumbersome.
Thanks in advance
b
Have you tried the VrayRawShadow pass? If you take that, invert it in Photoshop, then multiply it in it should do what you’re asking for.
nope - didn’t see that one so I’ll give it a try. Thanks
b
So I gave it a try - it’s pretty much the same as the VrayMatteShadow. It too is noisy. Is there some other way/trick people have of getting a good shadow pass without a lot of aggravation?
b
if its too noisy is it a render quality problem? Ie more light samples etc?
It does not seem to be directly related. The samples are good enough in the beauty pass. I think Vlado explained the reason for this before and there’s not really much you can do about it, that’s why I’m trying to figure out a good workaround.
b
The samples in shadow element are the exact same samples as used in the RGB element, however V-Ray will only put enough of them to get a good RGB image. You can try increasing the shadow and light settings to improve them.
That’s too bad. I wish it were a cleaner element too.
That could get expensive in terms of render time though.
b
Yes, of course; that’s why V-Ray only takes as many samples as required for the RGB image :slight_smile:
:slight_smile:
So no good (cheapish) workarounds?
b
None that I can think of right away other; it might be a good idea for us to add the “consider for AA” option to all render elements, and not just the ExtraTex one.
great idea :slight_smile: when it coming along. post work is very important. thanks vlado
