Sharpening/Blurring in C4D DB 5th Apr
  • Adjusting the Blur radius does not update in the image, until something else is changed (e.g. adjust the Sharpen amount and the image will update, or enable / disable bloom and glare, and the image will update).
  • Disabling Sharpening/Blurring with the checkbox does not actually disable the effect (and doesn’t update any changes made to the Blur) - though adjusting something else, e.g. enabling / distabling Bloom and Glare, will then update whether the Sharpening/Blurring is enabled or disabled.
All tests above in the Corona VFB only.
Thanks!
Tom
  • Sharpening/bluring should be fixed in daily build released today.
  • There is still similar problem with Bloom and Glare when used from C4D picture viewer, that should be fixed in next daily build.
Aleš
Thanks! Will restest :smiley:
Confirmed that sharpen / blurring is working as expected in the VFB now, ty!
