Sorry if this has been covered, but I wanted to ask about hooking up the VrayHairMtl3 with the new Shave v7.
In the past the way to connect this was to
1) set shave to geo mode in the shave globals
2) turn off “override geo shader” in the shave attribute editor
3) assign a VrayHairMtl3 to hair by right-clicking on it and choosing “assign new material” from the dropdown.
I believe that with the new version of shave (v7) there are better ways to do this now. Could someone please outline what that new workflow is for getting shave7 to work with the vrayHairMtl3?
You do not need to turn the hair to geometry. You can use hair primitives. To assign the vray hair mtl you can select the shave display node (in the shave display group) and then assign your material to that. You still need to turn off override geometry shader to see your material but that’s it.
Thanks for your reply Dmitry! When I do this it renders grey. It only seems to work if I turn the shave globals to geo rather than prims. Once I switch to geo, prims is greyed out too.
Steps:
1) make sphere and assign shave hair
2) assign vrayMtlHair3 to the shavehair node (outside of the shave display group)
3) turn off “override geo shader” in the shave attribute editor
Hair is grey (indicating that the shader is not being applied). If I switch to geo in the shave globals it works fine.
Alternately:
Steps:
2) assign vrayMtlHair3 to the shaveDisplay node (inside of the shave display group)
Hair is black (indicating the render failed). If I switch to geo in the shave globals it works fine here too.
4) create a vray hair sampler node, connect to hair3 shader
So where about is this Shave Display Node/ Group?? These terms are used differently between packages so I’m lost. (Manual isn’t much help either). Just need a hint for where to plugin the vray material into shave thanks.
When you build a shave hair, it creates three nodes; the shaveHair node, a transform group for organizing the display nodes, and the display nodes themselves.
Spin down the shave display node in the outliner, select the shave display that corresponds to your hair, and assign hair3 to that node. So if you graph the vrayHair3 in your hypershade, you should see it connected to the shaveDisplay mesh.
When you hook up the vrayHairSampler, just connect its color/transparency to the vrayHair3.
Hi Zach thank you very much for your help, appears to be working now. Thanks for pointing out the vrayHairSampler. I didn’t know about that node. By hooking that up you mean plugging it into the Hair3 Overall Color and Transparency channels inside the graph?
Playing around with the VRay Hair Sampler. I noticed that when I map the out color to the overall color of the VRay hair material, Vray uses the colors from the Shave Hair Shape node. I actually like the look better except it takes 30% longer to render. Anyway, I thought that was interesting and wondering if there was another way to use the colors from Shave Hair.
What we do is plug the diffuse output of the hair Sampler into these inputs of the hair material
diffuse color
secondary spec color
transmission color
This will pipe the nHair color, with randomization, into the vray material. You can also therefore use UV maps applied in the nHair color. We keep the other parameters pretty standard (based on the presets) but raise the diffuse a bit up to 0.2. With the presets it’s important to have GI on to get a good look.
Optionally you can also connect the vrayHairSampler’s distanceAlongStrand output into the vCord of a ramp texture and then input the ramp into the material’s transparency to get tip fade (the ramp should be black at the bottom and white at the top for the tip, using an exponential falloff). It is preferable however to do this with the hair system hair width graph as adding transparency to the material will increase the render time.
I’m at a loss on how you are using the paintFX hairSystemShape Node along with the Vray Hair Material. Are you somehow graphing them together using the connection editor?
I only ask because just hooking up the diffuse, secondary spec and transmission to the vray hair material, doesn’t appear to change the colors or use the color randomization field from the Hair System Shape node for paint FX. So I’m thinking you are graphing something with nHair colors that I’m not understanding.
For Maya nHair that you can add a vray attribute to the hairSystemShape and connect a Vray Hair Material to it. Much easier than with Shave. Then in the HyperShade you connect the hair Sampler (middle mouse drag) into the various inputs of the Vray Hair Material in the attribute editor. By default it connects the outColor to all of them, which is what I want.
Ah ok, so you don’t use Shave at all then I presume. I was hoping to use shave dynamics, it’s faster and better performing for me. I’m creating long hair which isn’t easy.
