it seems as if i have to manually go in and turn on all show maps in viewport for all the materials after converting a scene, is there a way around this?
Views > Show Materials in Viewport As > Shaded/Realistic Materials with Maps .
But it is a global switch and if you are using any special maps like falloff,VrayDirt ..etc then you need to fix them manually.
Regards,
aha, only used that in some cases, very helpful, thanks @M.Max
