Single .exr renderings messed up on Linux...
Hi @ll,
I’m having problems with the output of single .exr files via command line render on Linux (vray 2.30.01 / core version 2.00.01). Any other file format renders fine including multichannel EXR’s, but when i render single .EXR files (regardless of compression and 16bit / 32bit) the renderings are all messed up. Any ideas why this happens?
As a workaround i wanted to output .vrimg files but vrimg2exr will not execute on CentOS 6 (x64). Can anyone help?
Thanks in advance,
Rasmus
Are you using Maya 2013 batch rendering, or just V-Ray standalone?
I’m using Maya2013 command line rendering…
Then you will need a newer nightly or stable build. Please email us to vraymaya@chaosgroup.com for information on how to get access to those builds.
