Sketch up materials
Will Vray for Rhino materials work in sketchup??
Also i have a large library of 3DS max materials can they be converted into Vismats to work in sketchup???
thank you
Re: Sketch up materials
I believe that the VfR materials should work in VfS. There may be exceptions depending on when you saved out the given materials as there is no forward-compatiblity. We have a vismat exporter that will export V-Ray for 3dsmax materials into our vismat format. That exporter is in its infancy - but it may be useful if you have V-Ray for Max materials. You can grab it in our downloads section.
