When is Enscape3D expected to support SU2021?
Install SKP2021, go to your user folder, subfolder AppData\Roaming\Sketchup\Sketchup2020\SketchUp\Plugins, copy the folder āenscapeā and the file āenscape.rbā to AppData\Roaming\Sketchup\Sketchup2021\SketchUp\Plugins and youāre set.
Just tried launching, works just fine. Canāt speak for rendering stills/videos/panoramas though, havenāt tested those yet.
Thank you MatthiasL for your time. But, are you sure? Copied all non + visible items from and paste to. Enscape isnāt starting.
For me it worked, are you sure, you copied it into the right location? If you did it rigth the bars should be available as shown by @Dadi_1 .
Thanks for reaching out. Not in list.
Hi MatthiasL, thanks for your follow-up mail. The strange thing is that I have E3D up and running in 2020. If I consult the indicated location, I canāt find any folder with the name āenscapeā in the hidden and unhidden parts. Iāve checked if E3D was installed on another user. It wasnāt the case either. A search under all the users for āenscapeā results in hits for the Documents folder where renders are and downloads⦠I guess I wait some time
did you install SU correctly?
Right-click on installer and select ārun as administratorā
A lot of plugins will fail if you donāt do that.
Hi Paul, lately E3D is offered as an *.msi which doesnāt, offer to my knowledge, that functionality as with a *.exe?
Not Enscape ⦠Sketchup
It works well!! thanks
I like to wait a few weeks before updating new software releases (Enscape has been good thus far, I must say, though!). Let some bugs iron out. Although, not much has changed (again) as far as I can tell aside from the logo so⦠![]()
Works perfectly! Thank you
Paul, one credit for you!
I seems one install slipped to have it installed with adminā rights.
#upandrunning
THIS AINT A WORK AROUND ITS A BODGE
Itās a workaround until they implement compatibility with SKP2021 - itās not like youāre being forced to use it for now. :rolleyes:
