Hi there - I always used SU 2025 to export building models to 3dsmax.
Even though the model is in mm, I had to change the FBX model units to cm when exporting to 3dsmax.
FBX exports correctly and is scaled in mm in 3dsmax the way I want it.
The problem now is that I use the same settings in SU 2026 (26.2.243), but the model is scaled way to big when exporting to FBX and opening it in 3dsmax.
I change the model units to cm in the export settings and close and save it, but when I go back in the settings it shows the default “model units”, not cm.
In SU 2025 it shows the units you exported as previously when you go back in to the export settings.
So maybe SU 2026 does not pick up the changed units and defaults back to “model units”?
I’ve tried all the various units like mm/cm/m/feet/inches etc, but get the same scaled FBX model in 3dsmax?
Even though the unit scale in SU is set to mm in the work window, the FBX export scale is like a 1000x too big?
Does this make sense?
Please advise.
Thanks!
