Sketchup v-ray rendering window does not appear
I installed v-ray trial version to my sketchup 7
but when i press randering button on the toolbar render starts but i get no rendering window nor outcome of the render. the render just ends and everything is like before rendering
how could i get my renders visible?
Re: Sketchup v-ray rendering window does not appear
i tried with another file and frame buffer appeared
i opened the file I wanted to render again but it wont render even though the VFB window is open.
i exploded everything in the model and now it renders javascript:void(0);
i hope i dont need to make any changes to the model anymore..
Have you imported something into your model from another model? That ruins your model and it can never render again with vray unless you copy everything into a new model… Yet another bug in the new vray…
No thats happens with me all the time thats why i was uninstall new one change with old 1.05 there no problem like this with old one.The problem appears its because your skp file is to big to handle for your computers ram.So you need this patch to patch sketchup after it should be fine.
http://www.filefactory.com/file/b3f466h/n/4gb_patch.zip
