Skybox image tilt
I photograph often my clients areas with 360 cameras, and using 360 images currently is a bit tricky - basically I have to photoshop them in. The reason for this is, I cannot take 360 images of every imaginabel spot in the plot, so I can’t 1:1 set the images with the camera in the renderign progress.
I also do visualizations with Blender, and there it is easy to adjust by tilt shifting X/Y values for the image.
So, as you can rotate the 360 image, you should also be able to lift it up/down. This would be a game changer for 360 image workflow. I know it does not work 100% and without getting distorted, but often the background is only seen through glimpses and gaps - and in those situations, just a general view that is 70-80% accurate, works just perfectly.
Thank you.
