small environment fog bug
Create a vray env fog, select a gizmo for it. Create a 2nd vray env fog, select a different gizmo. Now select the first vray env fog and the gizmo selection stay on the 2nd one just created. The only way to do this is to select the first one, close the env rollout and re-open it.
Also if you creat vray env fog and select the gizmo. Save scene camera. After render in render batch. The vray fog will ignore the gizmo and apply fog everywhere.
