ive got a smal problem with a tree i construckted. to get some more leaves, i used particleflow with instancing geometrie.
now i wanted to convert the whole tree to vraymesh. this does work for the tree itselve,
but using the snapshot which usualy creates a mesh from your particles (which are now instanced leaves), i only get a new particleflow system with the name "GPF-Quelle , instead of PF-Quelle…
without any mesh.
am i doing anything wrong ?
Tom
Often you can snapshop pflow properly… or at all.
I have a little script that will do just the thing for you. Its at home tho..
Actually I think this is it.. try it out and let me know if it doesnt work..
http://www.scriptspot.com/bobo/mxs5/pflow/pflow\_\_snapshot\_as\_mesh.htm
Ah Well i found it out…
its a bit tricky..
first create in the compound objects a mesher object,
include your pf system,
(it has to be transfered to 0,0,0 before)
and convert it to a poly or mesh…
arrgh.. but works
pffft.. too much trouble. just use the script
Hi Da force…
Your Script works like a charme compared to max intern workflow…
tom
