They had an Itanium build of max 4 or magma or whatever they called it several years ago. But Itanium never really took off. 64 bit workstation are just taking off, with XP 64 still going through all it’s little infancy problems regarding software, drivers etc. There is no use bringing out a build before people start having systems to run it on. This is the right time to bring it out, and I hope they will do it as fast as possible.
ya im not surprised…and they had better get off their asses and get it out…or there’s going to be a wave of people leaving max like those that left softimage when it became the initial XSI…
The main problem that Autodesk is facing with the 64-bit version is that Microsoft does not have an official development environment for 64-bit Windows yet - there are beta versions so that people can try it out like we did with V-Ray, but it’s not yet released officially. It is necessary to have a stable development environment so that the 3dsmax team and the plugin developers can use the same programming base for code compatibility.
Autodesk showed a 64-bit recompile of 3dsmax at the Sparks meeting at SIGGRAPH - although they admitted that probably they will not be able to release it in time for 3dsmax 8.
We just need Microsoft to hurry up and get Longhorn out, then I think we will see a lot of 64 bit stuff. The little demo they did of 64 bit Max was pretty impressive. Huge files opening up in 20 seconds all while runnin 4-5 sessions of Max consuming over 5 gigs of RAM… :shock:
I think that is great news that Autodesk is waiting and not jumping like the other companies in getting 3ds Max to 64 bit on a beta development environment. I think we should all applaud Autodesk for being cautious as many of us earn our livings with this great piece of software and other pieces like Vray. I rather wait and have a stable, robust 64 bit Max and not one that doesn’t work properly because Microsoft changes the development environment or something causing the 64 bit version to be buggy or break. Anyway that’s my rant!
Actually - just before we left for Siggraph, we managed to get the Linux port of the standalone working Needs more work on the UI and some code organization, but it can do everything that the Windows standalone does.
well, look like chaos is doing THEIR part. Dont hold your breath waiting for autodesk though… what would be the advantage of using the linux standalone as opposed to the windows standalone?
Heh, well I was actually only guessing at the Max part, as I always had the confidence in Vlado and the team (Linux is a locical step for standalone environments I would think). But still, I’m gladly surprised to hear you’ve gotten this far
Well I looked at the 3dsmax8 beta - nothin’ really awesome and totaly new. Viewport has been accelerated quite a bit, but it needs more ram, especially if you’re draging 1.000.000+ polygons in wireframe mode.
Hair and Fur still drops max then mesh is quite big (1million+ polys).
I didn’t see the demo myself but was chatting to a guy at the Vray booth at Siggraph who said that Discreet did a demo of 3ds running in 64Bit. He said that it was pretty impressive and very fast. I have a gut feeling that we will be seeing 64bit 3ds 9 - sooner rather then later, whether they rebuild the entire code or not.
The advantage would come if you want to build a render farm - you can install Linux on the server nodes instead of paying for Windows licenses.
That’s awesome news. Is there a OSX port in the works? I was deliberating picking up a Mac for my publishing work - this would make it a greater incentive but I’ve been hesitant to drop the cash on something I may ocassionally use…
Why? Every publishing program used on the mac is also available on PC, some better (for instance Illustrator has issues on OSX Tiger, and the Adobe Suite / In Design are missing features on the Mac side). Why purchase a second expensive machine for it?
