[solved] Corona scatter issue
i have problem with corona scatter. I made ground (plane + noise mod), and use corona scatter, but my grass look strange, i dont know why. Any ideas ? :smiley:
My first thought is you probably want Align to Normal set to 1 to keep the grass upright. My second thought, is that you want to check the pivot point of the original grass and make sure it’s aligned in a way that makes sense (so that “up” for the pivot point is “up” for the grass).
Pivot is ok, i checked it. Changing align to normal to 1 doesnt help. I want to get something like that:
It’s not only position of pivot that matters, but also its rotation. Apply reset xform on your grass patch and see if that helps.
Yep, I would try selecting the grass patch, then Hierarchy > Affect pivot only > Center to object, Align to world, and then Utilities > Reset XForm just in case, and then convert to editable poly.
Thanks, it work ! :wink: grass look much better.
