[solved] Light Material
Is there a Corona light material? Basically, anything can give of light with the material applied.
Yes there is. It’s called CoronaLightMtl :smiley:
I looked, but didn’t see it. I’ll look again. Thank you!
There are two ways to make things glow:
-Corona Light mtl
-Corona mtl with self illumination enabled
It is very important to understand the differences between these two, and not use one instead of the other. For more info on this, see:
https://coronarenderer.freshdesk.com/support/solutions/articles/5000515603
And this recently released two-parter may be helpful too!
