Hi, everyone =)!
I`ve started to study 3dsMax and Corona 2 months ago. Here are some works made in Corona.
More works here https://www.behance.net/Julia_Wagner.
Julia
Hi, everyone =)!
Julia
These are great! I like how well lit and defined these are without any hint of burnouts. Would you mind explaining your lighting / post production setup? Do these images vary a lot from the raw renders?
Great images! Only the concrete edges in picture 3 are a little harsh.
Thank you =). I completely agree about edges, it was my first work, made some mistakes.
Thank you very much! =) I use Corona Enviroment + sometimes Sun for daylight interiors. When it`s necessary, then Corona light + ies. For exteriors I use HDRI +Sun.
Post-production depends on the certain picture, but usually it doesn`t take much time, only to add contrast and to fix some color tones. I make cmasking wirecolor after rendering. But for exteriors it takes much time. Usually I save pictures in png format. I always try to make renders as close to the final result as possible.
great work! Can you share your Corona Enviroment, Sun, IES settings please!
I’m realy curious, it looks so real and easy.
Are you saying you use the corona environment sky, but without the sun? I guess that works as a soft global illumination… hmm
