So I’ll be shooting video with speech with a Nikon D3100 and the built-in mic. The catch is the action and speech is happening outdoors right next to an aircon condensor. I’m geussing the mic will pick this up as a loud noise.
Is there any way to edit it out or at least make it less noticeable so the speech is clearer using Premiere? (any other mic except for the built-in one is not an option)
no - removing noise from audio is never satisfactory
been there done that
get another mic - it IS the only solution
..try a tie pin mike (sony shops sell them) (wireless or not) and connect it to another camera and sync up afterwards - not as hard as it might seem
mics MUST be close to the speaker unless you are using pro mikes with targetting tubes
or overdub afterwards, but that really is hard work
Oops! I’ll have to live with bad sound then on this one. My DSLR doesnt have external mic input (Nikon D3100), and don’t have 2nd device I can use to record the sound.
Good thing then it is just a private project, and not for a client.
simple trick, but not perfect :
Sample again, at the same place, the aircon alone (with nobody speaking) sound.
then use a noise reduction plugin (like sonic foundry NR) in soundforge (for example). You can “explain” to the noise reduction plugin wich is the problematic noise, providing to it the file you recorded with only the aircon sound.
This method will drive it to remove this sound to your speech sound file. Not perfect but reduces noises significantly.
sound subtraction only works on a reasonably constant noise like tape hiss and an air con unit will be rattling and probably have a rhythmic beat to the noise - let us know what works!
if I happen to borrow a DSLR with mic input, would a shotgon mic be best for this sort of thing? A mon on the person wont work I think as they would be fighting and the mic would pic up the wind and their clothes rustling together etc. Not to mention physical contact from each other
