Spawner is shutting down
My VraySpawner is shutting down everytime when i start it. Never had a problem with, since this morning, when I start the spawner, the $max scene is loading and shutting down after one second. All paths are still available, no new installed plugins. Tried a complete uininstall, but no luck. Anyone knows something about it?
Thanks in advance
re
The exact same thing happened to me…I reinstalled the operating system to fix it.
Does vraydummy.max open in a normal session without trouble? maybe try opening it and saving again.
damn, I cant reinstall my OS every month ;).
I’ve tried that RErender, everything’s fine, no measurement issue, no plugin issue. I’m speechless, because it worked for me for three months. Thanks for your help.
Are you running it as a service or just an exe?
running the exe on all systems
I have had system that would not run the spawner as an exe, I don’t know why, but running as a servive worked fine on those systems. Other systems with almost the identical specs worked fine with the exe.
Hi RErender, i’ve tried the spawner service, same thing. Dunno what to do next :sweat_smile: . Thanks for your patience.
I have the same problem !
I have 5 machines (exactely the same) and one just shut´s down the spawner after a few seconds. I recognized that this machine opens “untitled.max” instead of the vraydummy file. Sometimes it worked
when running install_VRSpawn_service_50.bat again (in 1 of 10 cases)
Then the machine was rendering for about an hour, before the spawner
was shutdown again for no obvious reason.
ok, i’ve fixed it, had to reinstall my max, not very nice. The second problem i’m wondering about is the spawner-lag, when the spawner is started, it takes about 20 secs. until i can click anything else outside of my max, am I the only one with this lag and how can I fix this? It’s taking ages when I need to connect remotely to my 9 render-servers while the spawner is running.
