hi,
As you can see, there is a light flickering, or fireflyes on the vases and cooktop… How can I avoid this?
thank you.
SanMarti_Interior_02_CORONA_0003.exr (10.7 MB)
hi,
thank you.
thank you. I´m going to try it asap.
I´m no using rounded corner effect.
Can you show the material setup of the materials with fireflies? Maybe a workaround would be to change reflection glossiness to something like 0,999.
Oh, it’s a blend material. What kind of lights are you using? It would help if you could send the file. You can submit a new support ticket with the file ( https://coronarenderer.freshdesk.com/support/tickets/new ) and we will take a look.
file sent.
thank your for your help!
Any adviced on the setup would be really appreciated.
