If i wanted to control the specular reflections on a object with a map where would you load the map? Would you put the black and white image in the button next to the relect in the vray material.
I think that you can place it in the reflection slot, white would be high reflective and black non reflective, then you should setup your glossiness value to a number less than 1.0, wich mean the sharpest glossi value you can get.
Dont forget to check the fresnel option too, to be able to keep the diffuse color.
Hope this helps,
Gonçalo
Thanks Goncalo i will try it!
