Morne
September 4, 2014, 1:16pm
1
Hi all
From a user input I set the raw vrimg file, then I use the dir and filename part of that file to also set the split channels, it saves the vrimg file but it does not save the split channels
RAWFile = getSaveFileName caption: "Save V-Ray image file" \
filename: "C:/_VRay RAW Renders/" \
types:"V-Ray image files (*.vrimg)|*.vrimg"
if RAWFile!=undefined then
renderers.current.output_saveRawFile=true
renderers.current.output_splitgbuffer=true
renderers.current.output_rawFileName = RAWFile
RAWSplitChannelFile = (getFilenamePath RAWFile) + (getFilenameFile RAWFile) + (getFilenameType "*.exr")
renderers.current.output_splitfilename = RAWSplitChannelFile
max quick render
If however I keep the name I set for the channels, and merely click on browse and then ok and render, it DOES save the files?!?
What am I missing here?
Hello
You need to set something to renderers.current.output_splitbitmap like:
tmpbm = Bitmap 10 10 fileName:RAWFile
save tmpbm
renderers.current.output_splitbitmap = tmpbm
max quick render
close tmpbm
free tmpbm
so that it is initialized to the required Max structures. A similar thing happens when you click browse and OK.
Yavor
Morne
September 5, 2014, 7:24am
3
Hello
save tmpbm
max quick render
close tmpbm
free tmpbm
Yavor
Jip, that did the trick
Thanks Yavor
Rens
September 5, 2014, 10:09am
4
Also see this thread for some more information:
http://forums.chaosgroup.com/showthread.php?70583-output-passes-to-separate-folders/page3
You don’t need to render the temp bitmap, just save it first and then assign.
Also, you can replace (getFilenameType “*.exr”) with “.exr”. ; )
Morne
September 5, 2014, 10:23am
5
Cool thanks
Over there at Mackevision dont you guys need some mid/senior generalists with junior scripting knowledge to eventually work into TD status?
