Seems I have the splotch problem also..I scaled the scene, relinked, collapsed etc.. Changed the clr and normal thrshold to .1, .05 etc…Still the same…Any suggestions are helpful. Oh and I seem to have a little light leak in the windows.
Thanx all
you need to post a SS of all your settings.
well all your settings are pretty much overkill cept for your hsph subdivs. Try boosting to 100 and see if the splotches go away. if they do, lower it some and keep test rendering until you get a good quality/rendertime.
The chiefs? doubtful ![]()
great…will give that a try…which settings are overkill…Just so I am not wasting time…Thanx
try -3,-1 for your irrad map and .94 .05 for your qmc. Also for stills, I frequently dont see much of a difference between 500 LC samples and 1500. I did a test once with an image, one at 250, and one at 1000, put them into photoshop and did a difference layer for them both. It was nearly completely black, only when I did a contrast move was I able to see some white coming through.
Once you get that cleaned up, fix up the AA problems with the sun on the floor.. might need to tick clamp output so the AA can work properly, and maybe add just a dash of area shadow.. might need to increase the size of your sun a jot, then that render will look pretty sweet ![]()
Pillows are a tad shiny tho.. leather pillows?
Percy, mind if i ask why the .94 and .05 for qmc (i assume for the adaptive amount & noise thresh, correct?).
Regards
Harry
because its just been what I’ve used from time to time. Really depends on the scene. Sometimes I use .96, .015, whatever works.
Thanx all…I will try those today…Leather Pillows?? There’s a joke there somewhere.
The sun on the floor. What exactly does AA do? Will it make it a SOFTER light or feel?
well you can definitely take advantage of Adapt Subdiv on this type of scene, so i wouldn’t change the image sampler type, but you definitely need to increase the sampling. I would use a Min value of 0 and a Max value of 3 or 4. Test a Clr thresh value of 0.05 as well.
If you want to remove those splotches, I would increase the IR interp. samples first. I think you’ll find that this setting will have the great impact. I recommend starting with a HSph Subdivs value of 20 because this can greatly reduce rendering time and if other settings are adjusted properly, you won’t have those splotches.
How do I adjust he area shadow…By increasing the sun?
Yup, sun size multiplier (dosn’t affect the intensity)
hmmm…interpolated samples blur the irrad map, so I wouldn’t go above half your hsph subdivs unless you have a really good reason to.
That lamp looks almost as bright as the sky outside - it shouldn’t be anywhere near as white as that. Maybe a bit of bloom around the windows in post too. Looks good though.
Maybe some “show samples” ?
Well, actually maybe you can try to turn on Detail enhacement ? Will see if splotches go away.
Do set a very wide scissor between min and max IRMap settings, something like -7/0 or thereabout, and watch the splotches go away ![]()
Lele
i would also turn off the light for the final…looks weird with bright day outside and internal light on
best regards
martin
Lele,
I’m curious…have you gotten this to work before with such a high Max value. A Max value of 0 is usually going to give you great deal, ie, reduce the size of the splotches and in effect make them stand out more. Also, I can’t imagine a scenario in which vray would even settle for such a low Min, unless you went crazy with some of the clr, nrm, dist, thresholds. On a 1000x1000 pixel image, -7 would yield a irradiance map resolution of 8x8, which would never do an image any good. Lowering the ir map resolution certainly removes the splotches but reduces detail. Inter samples reduces the splotches by adding additional information between the samples, and doesn’t have nearly as dramatic effect on blurring of detail. In other words, a Very Low preset (-4/-3) can give you a very smooth image but not much detail. In this scene, to maximize quality/versus render time (assuming render time is of some importance), I would use:
Medium preset
20 HSph subdivs (you really don’t need more than this on this kind of scene)
50 Interpolation (increase as necessary to remove splotches)
Adapt QMC with a Min/Max of 2/5 (or 3/6 if necessary)
Disable the ‘Use QMC thresh’ value and lower the Clr thresh to see if there is more detail to bring out without too much increase in render time
Leave the QMC Noise thresh at 0.01
As mentioned, i would definitely turn off the interior light.
Just my humble opinion
