Is the ss in the vrayMtl broken?
It does nothing here.
Im rendering with CPU on Vray5
Here is the scene file.
vmtlsss.rar (29.9 KB)
You need to add some refraction to the material so that the translucency is visible. Note that the fog color will be visible as well, so you may need to tone it with a darker color to see dominant sub-surface scattering in the result; the effect is stored in the refraction render element.
Is there something about this workflow in the Vray Documentation?
I tried it now. But its hard to balance those attributes.
Im back to the ALSurface.
I’ve never found the SSS attributes on the Vray material to be any use, ever. If you want a truly subsurface material, use the SSS shader.
I was hoping that in Vray 5 we get the same feature with the translucency like in 3ds Max. There is a work around in Maya. Do not use the normal VRayMtl use a Vray Plugin node “BRDFVRayMtl” instead (Create → V-Ray → Create From V-Ray plugin → BRDF material.
We are using this for all our plants. I really would like the know the reason why the VRay material is different to the one in 3ds Max, even in VRay 5?
Here other test with SSS + Thin Walled
​​​​​​https://www.instagram.com/p/COx\_qeSI\_vs/
this isnt supported in GPU is it?
the new SSS is hidden the GPU UI, looks like this is gonna take a while
No, it’s not yet supported on the GPU. But we’re working on it.
