Standalone exe not working in sketchup with enscape trial version
Is the standalone exe creation feature supposed to work for sketchup in the enscape trial? This is one of the tools I would like to test
Welcome to our Forum!
The standalone feature is the only feature disabled during trial mode - the reason is simply that too many architects would download the trial, export every single one of their projects as a standalone, put them on their website and not contact us afterwards.
However, you can always have a look at our example standalone files on the bottom of our gallery, you can watch the export process in this tutorial on Youtube.
Let me know if you have any more questions, or if there’s anything else I can help you with!
Thank you, makes sense
Scan we use the standalone web app as a link in our website without showing that it’s a sketchup model?
You can link a Web Standalone and while the loading screen itself will still display the Enscape logo, it should not be visible through which CAD solution the export was processed. Hope that helps! Let me know if I did not understand it right. :slight_smile:
On top of that, you may also want to refer to the following article for more information about our Web Standalones and even how you can embed them directly on a website, just click here to get to that knowledgebase entry.
Finally, click here to get into a Web Standalone that has been exported through SketchUp.
If anything is unclear just let me know!
Thank you for the info and links,
I requested an invoice for one floating license so that our business can purchase a license. Is it possible for you to request that on your end as I dont see how to get to a person in the accounts section.
One more question; if we transition from sketchup to revit does the same license apply?
Hello @natasha_avelange
You can contact our licensing department via
Your license is not bound to a CAD, it will work with all of our supported CAD programs which you can find here.
how do i change the login id on the SketchUp enscape? I am not receiving any license key since then from your end but only getting the download link
Please get in touch with if for some reason you do not receive your dedicated student license which you’ve acquired. For any educational requests generally please refer to the EDU team via that address.
