Stereoscopic helper problem
I´m having a problem with rendering side-by-side images in an animation
with “adjust resolution” set in the stereoscopic helper.
When rendering a single image, the frame buffer shows left and right image
side by side, but when rendering with save file on (in an animation), only
a single image (left) is saved to disk, not both images (left and right) in one file.
I´ve attached a simple scene with a teapot that demonstrates the problem.
Maybe I´m just doing something wrong ?
This is with max 2011 64 / Vray 2.0.0.2
Best,
Martin
stereoscopic_renderproblem.zip (21.3 KB)
It will work if you save to any file format other than JPG. This is an issue with the 3ds Max JPG saver and the particular way that V-Ray uses to resize the output image.
