Hello.
This is a very strange DR problem.
All bitmaps are copied to the nodes so this doesn’t seems to be a missing file issue. I even checkes all enviromental maps.
The buckets rendered localy (in the workstation) are slightly darker and not even uniformally darker as you can see in the first image.
The second image is rendered without DR and its ok.
So…it seams that the problem is in the local machine but it only happens when usind DR??
What may be causing this??
I’m using IR for 1st bounce and LC for second.
I’m not using any enviromental maps.
Any ideas?
