strange texture + lightning
hey guys I wanted to make a quick render of my WIP and I noticed some strange thing in my texture which I marked with red. I applied the texture to the group because it has displacement and otherwise I can’t get it to work. Is that normal to apply materials with displacement to the group (not each individual face)?
I also notice the weird lightning (those spots). Normally I use single faced glass with no see through material. Now I used a 6mm thick glass with the “clear glass” material. I used vray sky with physical cam.
here’s the render:
thnx in advance
Re: strange texture + lightning
oke the glass problem is solved… it didn’t have “affect shadows” ticked
Did you apply soften/smooth edges via SU? If so check the degree figure, so it’s not too high.
hmm… I NEVER apply materials to groups/components due to the increased render time and smooth geometry rendering faceted.
I didn’t think that materials applied to groups/components would show displacement. However, you do have to group the faces you apply a displacement material to. If it’s connected to any other material the displacement won’t take effect.
oke good to know it’s better to not apply materials to groups. I’ll try to group every single face. Hope that also fixes the stange texturing a market in red.
thnx for the replies
btw I didn’t use soften/smoothen.
It looks as thought the normals are poorly built around that area. This is typically the case with long thin triangles, which appears to be the structure of the underlying geometry. Displacement will use the normals of the geometry to displace the mesh, so if those aren’t consistent and uniform, then it will lead to some undesirable results.
Can you post screenshot of the model from SU, all white with black lines - and hidden lines on?
the render is done without the faces subdivided… I just added them recently and wanted to give it another try.
my new render:
What I now did is apply the material to the faces and then made 1 group out of it.
btw It rendered way faster applying materials to the faces itself and not to the groups
What texture is that? I quite like it, but i dont know what it is!
I’am trying to get a nice reed teture 8)
looks like an interesting project!
yeah it’s a pretty intresting villa from one of our clients and I hope to finish it after my holiday
oke I ajusted the model a bit and now I doesn’t displace anymore.
this is what it looks now:
Are all the ‘reed’ faces grouped?
yes (it’s all in 1 group) it worked before now I edited a bit… used subivide and smooth and at the top I made it more compact
Could you upload the model? Maybe it doesnt like the fact you smoothed the edges somehow. Or maybe the smoothed edges have ended up on a separate group/layer within the reed group? You could try exploding all those reed faces and regrouping? You may have tried all this already, just some ideas.
Just out of interest, I was going to buy the subdivide and smooth plugin, but I am sure on his website he said it was not compatible with Vray for some reason. Was that an older version of Vray?
http://rapidshare.de/files/47942672/2638\_Chris\_24-07-2009.skp.html
if u need the reed texture I can upload it aswell… reed is called riet (Dutch) in my model. There’s a free ‘light’ version of the smooth and subdivide (not sure). I use round corners for it not subdivide
ok Remon, I’ll check it out now and see if I can get it to displace.
Remon, can you save it as SU6 I dont have 7 :-[
http://rapidshare.de/files/47942731/asgvis.skp.html
