Sub-pixel ON-OFF : phisical INCORRECT, noise and rendertime
Hi Cecofuli,
Like you i struggle a lot with these render times and noise when sub pixel and clamp are off.
I obtain the best result when i clone all my lights: the first light is set up with a big intensity but it is only affect diffuse, the clone light is set up with a very low intensity but it is affect only specular( and eventually reflection).
I do that because i noticed that often noise and very long render times are caused by lights with big intensity with affect diffuse, specular and reflection checked.
With my set up, i find that the lighting is much more natural( without these very very bright dots wich are so long to render), and a lot faster.
Perhaps it could help you.
regard’s
Dam
Hi Dam,
nice tricks, but… I would like to prefer a “real world like” solution… I want to try with PT (LC+LC) and see what happen…
But, as some other competitor do right now, in my opinion the solution will be a Path Tracing (or any progressive render) as primary bounce and LC for secondary… Like Vlado wrote some messages ago.
