subscription : state sets
I am not sure if this questions is better to be asked to Autodesk or Chaosgroup, but I like you guys better :slight_smile:
I was just wondering is there is a way to make the state sets work with - object > vray properties?
thank you
best regards
John
We were not part of the beta for this advantage pack, so I’m not sure if that got fixed eventually. The only thing I know is that the info is accessible from the 3ds Max SDK, the guys who worked on the scene states have been aware of the problem for a long time, but I don’t know if they got round to fixing it.
If they can’t/don’t want to fix it, we may have to find other ways to store the object properties into the nodes, but it will be painful.
I’m told this should be working fine; I will need to test it tomorrow myself though.
So a further update - it appears this was fixed, but unfortunately the fix did not go into the official advantage pack installer. Hopefully it will be fine for future 3ds Max releases.
what a fxxxxx!!! i posted this issues at kens blog and hope they get fixed it soon AND before 2013…damn adsk, i am speakless!
Thank you for the research !
Too bad it hasn’t been implemented to this subscription, I was really looking forward to this.
Well, we’ll wait to hopefully have it into 2013.
Thanks again,
John
Well, I just checked on a relatively simple test scene, and this worked fine - the matte/alpha contribution properties were correctly saved and restored with the scene states. So not sure what’s going on in your case - can you post a scene here with some more specific reproduction steps?
i just checked it again…i only created 2 objects (plane and teapot), go to state sets, make a new state and go on record. now i turned on matte object in the vray properties (and set alpha contribution to -1) and stop recording. so when i switch from this state back to normal scene state nothing was stores and no node properties is changing like when i change something in the object properties dialog…using max2012, sp2, advantage package and vray 2.10.01
You are right, this does not work, so we can only hope for a fix in a future release.
yes, i also noticed that output path and render elements settings wouldn´t recognized too…too bad adsk.
Honestly, I would have been surprised if those things worked out of the box.
we should have a look into that…http://www.scriptspot.com/3ds-max/scripts/max-render-layer
vray properties are working perfectly, render setting were stored in separatly render presets, all is working just fine on a quick test…
For my part I will stick with RPManager for a while! It is the only pass system that I know that is working flawlessly in production even with vray.
I’ve heard a lot about RPManager but never tried it.
I guess I am gonna looks closer to that.
Thanks for the hint.
John
Because Vray Object Properties are stored and accessed from the standard Object Properties User-Defined Properties, and State Sets doesn’t track changes to it, they aren’t tracked. Sounds like a good user voice entry to track the User-Defined Properties. You can manually get/set the properties using maxscript, the Node User-Defined Properties, and scripted state sets.
-Eric
Vray renderer is working and was intended to be supported with all parameters of the renderer tracked as well as lights, cameras, etc. What did not make it into the Subscription Advantage Pack release is tracking of Vray specific Object Properties as Eric pointed out. Regular max object properties should work with Vray but Vray specific object properties expand max object properties and add things like Receive/Send GI and Matte options. We are investigating adding support for these specific object properties but can not comment on when in a public forum. We had to get the standard Max features working right and stable before expanding to some of these additional properties.
Please note there is a way for these additional options to be achieved in the Subscription Advantage Pack by making use of a Vray Wrapper Material that will set all the Vray Object Properties. Using the Wrapper Material is not ideal but it is a workaround to achieve Vray Properties per object or group with State Sets.
Just FYI Shane, you don’t need to track anything Vray Specific to get support for the Vray Object Properties as they are assigned in the User Defined Properties of the Object Properties. As long as you track custom user defined object properties, then you will get Vray support for those for free.
-Eric
