I have a problem when I uncheck the filter maps (in render setup global switches), the substances materials become black (work fine in Max 2011, Vray 2.00.02).
Have you this problem too??
This seems to be a problem of the Substance maps; the same problem happens with the scanline renderer when you turn off map filtering. It would be best to report this to Autodesk so they can fix it.
Thanks Vlado, and unfortunately, sp1 don’t fix the problem. I create a post in “the Area” but no answer for the moment.
