I have used material " Substance Source "
But it does not work with the aura
Also other programs with " Substance "
It is the only solution to take out maps only with items
Then install it manually?
There is no compatibility and this is surprising
“Substance”
A very important site for content makers, and I am surprised at the lack of compatibility
thank you
I’ve seen it before
This is for import
This is not useful
When you import materials and drop them onto the form, you will not see the materials as they are in the form
There is an incompatibility
Explain here your import
And "Substance "
He says that there is a compatibility between him and Corona
Just words from words
There is absolutely no compatibility
You subscribe to "Substance "
Then you discover a lack of compatibility
this is as far as substance is integrated into C4d,
complete your material or alterations in substance first and then import, (minor tweaking ok in C4D)
not sure what your question is , sorry.
C4D help file : https://help.maxon.net/us/index.html#55382
