Substitute modifier on vray meshes
edit:
the topic title should have been “vray meshes as substitutes”. the other way around it doesn´t make much sense.
/edit
Sometimes handling many vray proxies of heavy geometry can be a really tedious task.
It would be really nice if one could use a substitute modifier to choose a even more reduced mesh for viewport purposes. Right now it’s impossible (or at least I´m not able) to choose a vray mesh as a substitute object.
Implementing this doesn´t seem too hard from a non-programmers’s perspective. :wink:
Ooh… this could be really nifty.
Combustion does something similar with a “switcher” modifier.
I could see this being really useful when you are working with animated trees, but want to have a low-poly proxy be in the viewport when you’re not working on it.
Perhaps the Level Of Detail tools in Max could be used to this end? I’ve never tried them.
