Support for Animated Textures Between Corona and Vantage
Status: pending
Currently animated textures do not transfer between Corona Renderer in MAX and Vantage. When you try to use an IFL/image sequence the first frame only will display in all renderings in Vantage, regardless of where you are on the animation timeline slider. This is apparently a Corona/Max to Vantage issue only and seems to have already been sorted out for VRay/Max to Vantage.
Vantage appears to be an excellent solution for quickly outputting animations from files originally setup in Max. But the fact that animated textures cannot be used is a major drawback.
Submitted on AHA Ideas by Christopher Fuhrmann (CMAX-I-303).
AHA Ideas status: Pending.
Set during AHA Ideas to Discourse migration.
