Hi Chaos Team,
It would be great if Chaos Scatter could support scattering other Scatter objects directly. It would add a lot of flexibility to layering natural environments.
Thanks!
Hi Chaos Team,
Thanks!
Why not convert the said scatter to Max Geometry (Surface Scattering > Convert to Max Geometry), group it, and then scatter the group?
This can get heavy very fast, apart from being a destructive workflow.
I suppose you are right @Vizioen . The devs said it is possible to implement, which is a good thing. @santiago_gutirrezdepierespedraza I suggest you add this idea in the Portal too.
