Hi There,
We have 4 Vray licenses and 1 Render Node.
I cant seem to get to node to render when i start a swarm session.
2 of the machines in the office go to unstable.
Could you explain how i can get it to work?
Also, the node seems to be offline yet available??
Cheers
“Offline” means that the license is borrowed, currently on “MINA-PC”.
“Unstable” indicates a setup issue, or more often - a license issue. I can see there was 1 free license when the screenshot was taken.
Make sure that TCP ports 24267 and 20207 and UDP 24267 are allowed if you have firewalls on between computers.
See this for instructions - Chaos Docs
If you need additional assistance - don’t hesitate to message us at support@chaosgroup.com
Hi Ivan,
I can’t return the License as it’s not listed as borrowed.
Where do I set the ports… by default on the vray install I ticked the box for firewall exceptions.
cheers
Justin
