Swarm
I cannot for the life of me figure out how to get swarm to work. Main computer has full install, the server has Swarm installed. Server was given a tag through the UI but the Main computer can’t see anything. It was showing " no tags found" but after I put an IP that went away and now just shows a blue line with “add vray swarm tag”. Not a clue what to do now? Any help would be greatly appreciated.
Hello Christian,
Please check if your firewall is not blocking the traffic between the machines. Also please make sure that the auto-discovery in the swam settings in your 3d software is switched off. Please see the image I have attached.
If this does not help, please create a ticket from here so we can look into it further: https://support.chaos.com/hc/en-us/requests/new
