test images
I’ve been away from this forum and Vray for a few years. After having a play over the weekend I thought I’d share these test images created.
Its good to be back!
Any comments welcome.
cheers :slight_smile:
welcome back!
well you didn’t loose your touch, if anything, you’ve gotten better
nice renders and feel
Thanks for you kind words Morne! good to be back :slight_smile:
Hello, these look great! Only crit here is the long seam in the flooring on second image (roof terrace) is very distracting…
Make an actual control joint (i.e. Schluter strip), or lose that seam IMO…
Also, that image would benefit from some DOF.
Nice work :slight_smile:
Hi Voltron,
Thanks for your comments - Yes! I definitely think the seam needs to be killed, although i’m less of a fan of DOF because it tends to make larger scenes look small imo.
These images were only a test for an upcoming job opportunity; to see what could be done in two days. I will revisit them and do a proper beauty pass when i get some time :slight_smile:
Well, these are still great, and I should have written, “proper/subtle DOF” : )
best regards
