The scenes are not syncing between SketchUp (SU) and Enscape
Can anyone assist with this? 8|
I’ve set up about 100 scenes in SU using tween animation. When I click on the SU scene, the Enscape synced view is correct.
However, when I click on the same scene through Enscape’s View Management, it appears like it has reverted to the Default view, not the Camera angle I set up in SU.
I know that the Edit button on the right side of Management can adjust the Camera setting.
But I’ve already generated 100 scenes through SU tweens. Should I edit each of these 100 scenes manually…?
How can I solve this? Is there a way to adjust Enscape’s Default Camera settings or another method to modify these scenes?
Thanks.
I got it.
Change projection mode can fix it.
Thx
