Time for the yearly GPU rant
Alright, new year, new releases, next try for GPU next. Well, what can I say: It still doesn’t work. I have a 1080 GTX Ti with 12GB(!), and first things GPU Next says it’s out of RAM. Okay, try again with mip mapped textures. Now it says the stuff in the screenshot.
Really, I don’t get tired of saying how useless this is. Honestly, I try GPU whenever a new release is out, for the past 3 or 4 years. Never ever have I completed a single image in production conditions! What the hell am I doing wrong that others seem to get right? Is it the resolution? I don’t render silly animations in HD res, the stuff I do is for print in resolutions beyond 10k per single image.
Another thing I encountered: I have no secondary matte slot in the environment. How am I supposed to render a car with matte shadows on a provided background?
If you need the scene, tell me.
Yes, please.
I get it to work on a simple teapot scene, yay!
Next thing: The ground projection feature for the VrayHDRI doesn’t work. Showstopper for me. Will try again next year, thanks for the effort!
And something more: As I have to rely on mip mapped textures to get it to render in the first place, my backdrop now looks like back in 2002.
I just realized you already have it. It is the same scene as in the problem described here: 3.6.04: IPR CPU is very unresponsive on heavy scenes - Issues - Chaos Forum
Switch to Next GPU, watch it fail.
Sorry for your problems.
It is not out of mem. It says that you don’t have CUDA capable devices. It happens often on Windows update the OS to make them unstable.
Please reinstall driver 388, restart PC and try again. With this drivers, anything can happen. We don’t really controll this.
Resolution doesn’t matter for V-Ray GPU rendering.
Features that are not supported in the GPU engine are now disabled, so there is no confusion. There are ways to workaround the secondary matte in post.
The background looking so bad is strange though, I hope Peter will help there.
Best,
Blago.
Okay, will try to update the drivers.
The HDRI for the background is quite big, it is around 18k in width. Maybe something goes wrong when scaling it down?
We don’t scale background/light textures, so this is why it is weird. I hope Peter will be able to help by reproducing this here and we will track it down.
Best,
Blago.
It surely can fit on your GPU, just use the stable 388 driver. About the other things - I’ll check them tomorrow.
Okay, next try with driver 388. Still doesn’t work, I give up. Again. Next try next year. I am sure I will never ever render with this. It is beyond me how anyone can use this GPU experiment in production!
Best thing, I always have to restart Max after this happens, because at the next hit of the render button, I instantly get an error message.
That Andre Matos guy from Porsche, how the hell is he doing renderings with this? What the heck is the secret ingredient to get this stuff to work?
It crashes as soon as I render with materials. Rendering with grey override renders fine. Great!
Still, Cuda error 700.
Just tried another scene that rendered fine yesterday, even with driver 398.
Is it possible for you to send us the scene that causes you troubles, so we can take a look please?
Or it is with the scene that we already have? To be honest we checked that it works fine with nightly, we are checking with the official release right away.
Thanks,
Best,
Blago.
Okay, it seems like it works here as it should and we can’t reproduce this crash.
We will continue trying though, but if you have time to, it would help us to do a remote session whenever you can, so we can check if it us, or something with the env/setup.
Thanks for the patience and sorry for the troubles. Sometimes no matter how hard we try, there are frustrating situations like this .
Alternatively if you want, I can send you latest nightly build with some fixes to see if this will help. It might, but if it doesn’t, it will mean that we have wasted even more of your time. If you want to try it in advance though, please ping me.
Best,
Blago.
Well, I feel a remote session would be best. I can open the two scenes that are giving trouble, and you can see what happens. I’m out of ideas. We have teamviewer installed already, as we use it to monitor our rendernodes.
Perfect.
We can do anytime in the next two hours today or anytime tomorrow / during the week.
Please mail to blagovest.taskov@chaosgroup.com with cc to support@chaosgroup.com for what time works for you and for Team Viewer details.
Best,
Blago.
Okay,
I got the scene with the car working by hiding the wheels rear lights. For some reason the material on this makes the render crash, I have no idea why. Maybe I find the time to debug further
So I got my scene rendered in around 25min on a single 1080Ti in 4K.
Sadly I am not pleased with the result because of severe bugs, some of them I have reported over half a year ago! Following are some images to demonstrate.
First of all, here is an image from the same scene in CPU mode. There is no post work to this, this is straight out of the VFB. I know you can’t directly compare results, but still, this is what GPU has to fight against.
Now, this is the first result I got with GPU, minus wheels and lights. You can immediately see that there is something wrong with the VRayPlane set to matte shadow catcher. For some strange reason the car is getting illuminated from below, and I can not find the cause for this. Also, the shadow of the car is not showing up in the reflection channel. This looks like this very problem here, where I provided a scene for debugging: https://forums.chaosgroup.com/forum/…ection-channel
The noise on the black plastic of the inner wheel arch lining never clears up. Something is going on there.
Also, note the pink color spill on the license plate. This is caused by the VrayPlane. For some reason, the GlobalIllumination RE is all pink, something I have never seen before in CPU mode. There is a second problem to this: The pink color spill can be seen on the car paint in the GI render element, but not in the Beauty. That is an inconsistency that is not acceptable.
Continuing previous post, because of attachment limit.
Next up are the reflection and lighting channel. The strange illumination from below if nowhere to be found in the render elements. So these do not represent the final beauty RGB. Also not acceptable.
Reflection of the shadow is not present here, which makes believable renders quite hard.
In my opinion there is something terribly wrong with the matte shadow system in GPU. It has been a long time since GPU was introduced, and this is still not working correctly. There shouldn’t be any illumination out of nowhere. The shadow that falls onto the plane has to reflect back into any objects that are sitting on the ground plane. And most of all: We need the ground projection feature. This is essential in the automotive visualization field. As I said, that alone is something that stops me from using GPU for serious work.
Just for comparison I made a render without matte shadow system, but of course this is useless because I do not want to see the grey ground plane. Neither diretly below the car, and not in the reflection.
I don’t want to sound rude every half a year, but I can assure you that whenever a new major release of V-Ray comes out, I am testing exactly this. And for around 3 years, nothing has changes in that regard. Yes, the speed might have been increased, but still GPU is missing crucial features. Until these things are not fixed, I can’t even think of considering GPU for rendering. Too much hassle, too much problems.
Take my word: I will try this next year. I don’t get tired of doing this.
Thanks for your time.
The render crashes as soon as the wheels are visible. Can’t track it down.
I am in exactly the same boat.
The secondary matte feature is essential to our work and something that has been asked for on the GPU, several times, starting over 1 year ago.
All of the speed enhancements etc. are good, along with features like dispersion on the GPU, but the secondary matte feature is high priority for lots of us Automotive guys.
Also, I would like to know the ‘There are ways to workaround the secondary matte in post’ technique?
Cheers
