Hi. Time of day slider is missing. I have reset tabs and do not have a skybox loaded. see attached.
Hey @DaveG27 , the time of day indicator is only being displayed on the bottom right corner while the time of day is actually being adjusted. If you press the right mouse button +Shift and move the mouse to adjust the time, is the indicator not being displayed at all? Maybe you’d generally like to have an option to always have this indicator displayed?
Hi Demian. That is the issue. The time of day slider is not displayed when I am adjusting the time of day. it used to be displayed when I used the “U” or “I” .
When I do it with the right mouse button and shift it does work. So that is what I do now. Thanks.
Hey @DaveG27 , first off, could you make sure you’re using our latest release? If the issue is still persisting after the update, or in case you’re already using our latest version, may I ask (even though it may seem trivial), the actual time changes when you press “U” or “I”, but the indicator is not being displayed at all, correct?
