version 7.0 v8
push $cut_paste_input
Group {
name Tonemap
selected true
xpos -308
ypos -203
addUserKnob {20 tonemap l Tonemap t "Adjusts blend between linear colors and full tonemap"}
addUserKnob {41 operator l Operator t "Available operators:\nReinhard (V-Ray; desaturates highlights)\nExponential luma (modo, Maxwell; saturates highlights)\nFilmic (punchier look, darker shadows; more control over look)\nCorona (similar to Reinhard)" T Switch1.operator}
addUserKnob {41 mix l "Tonemap Mix" t "Blends between input and tonemapped image" T Merge1.mix}
addUserKnob {20 exposure l "Exposure Adjustment" n 1}
exposure 0
addUserKnob {41 mode l "Adjust in" T EXPTool1.mode}
addUserKnob {41 gang T EXPTool1.gang}
addUserKnob {41 red T EXPTool1.red}
addUserKnob {41 green T EXPTool1.green}
addUserKnob {41 blue T EXPTool1.blue}
addUserKnob {20 endGroup n -1}
addUserKnob {20 exponentialStrength l "Reinhard and Exponential Luma Controls" n 1}
exponentialStrength 0
addUserKnob {41 mix_1 l Burn T Reinhard_Merge.mix}
addUserKnob {20 endGroup_3 l endGroup n -1}
addUserKnob {20 filmic_1 l "Filmic Controls" n 1}
filmic_1 0
addUserKnob {19 Grade1_black l lift t "Lifts blacks" R 0 0.1}
Grade1_black 0.005
addUserKnob {41 shoulderStr l "Shoulder Str." t "Higher values produces brighter highlights" T Expression_Filmic.shoulderStr}
addUserKnob {41 linStr l "Linear Str." T Expression_Filmic.linStr}
addUserKnob {41 linAngle l "Linear Angle" T Expression_Filmic.linAngle}
addUserKnob {41 toeStr l "Toe Str." T Expression_Filmic.toeStr}
addUserKnob {41 toeNum l "Toe Num." T Expression_Filmic.toeNum}
addUserKnob {41 toeDen l "Toe Denom." T Expression_Filmic.toeDen}
addUserKnob {41 whitepoint l INVISIBLE +INVISIBLE T Expression_Filmic.whitepoint}
addUserKnob {20 endGroup_1 l endGroup n -1}
addUserKnob {20 Corona l "Corona Controls" n 1}
Corona 0
addUserKnob {41 compression l Compression T Expression_Corona.compression}
addUserKnob {20 endGroup_2 l endGroup n -1}
BackdropNode {
inputs 0
name Filmic
xpos -340
ypos -221
bdwidth 144
bdheight 193
BackdropNode {
inputs 0
name Corona
xpos -498
ypos -222
bdwidth 151
bdheight 194
BackdropNode {
inputs 0
name Luma_modo
xpos -171
ypos -212
bdwidth 274
bdheight 190
BackdropNode {
inputs 0
name Reinhard
xpos 116
ypos -215
bdwidth 243
bdheight 191
BackdropNode {
inputs 0
name Notes
label "Filmic tonemap operator is based\non John Hable's work for Unchartered 2:\nhttp://filmicgames.com/archives/75\n\nExponential luma operator is used by \nmodo and Maxwell.\n\nReinhard operator is Reinhard global.\n\nCorona is from the 3ds Max plugin render\nengine Corona.\n\n\nCopyright 2013 Simon Lundberg\nFeel free to re-use, adapt, distribute\nand change tool to suit your needs,\nbut please don't sell it."
note_font_size 25
xpos 582
ypos -307
bdwidth 616
bdheight 512
BackdropNode {
inputs 0
name Film_Simulation
label "NOT IMPLEMENTED"
xpos -663
ypos -224
bdwidth 141
bdheight 196
Input {
inputs 0
name mask
xpos -462
ypos -344
number 1
Dot {
name Dot11
xpos 499
ypos -341
Dot {
name Dot10
xpos 499
ypos 218
Input {
inputs 0
name img
xpos -578
ypos -344
Dot {
name Dot14
xpos -547
ypos -295
set N1a542300 [stack 0]
EXPTool {
mode Stops
name EXPTool1
xpos -462
ypos -298
Dot {
name Dot19
xpos -216
ypos -295
Dot {
name Dot33
xpos -216
ypos -241
set Naea67450 [stack 0]
Dot {
name Dot24
xpos -275
ypos -241
set Nb255c280 [stack 0]
Dot {
name Dot25
xpos -431
ypos -241
set Naea5ff70 [stack 0]
Dot {
name Dot28
xpos -612
ypos -241
Dot {
name Dot29
xpos -612
ypos -185
Dot {
name Dot30
xpos -612
ypos -62
Dot {
name Dot31
xpos -612
ypos 80
Dot {
name Dot32
xpos 19
ypos 80
push $Naea5ff70
Expression {
expr0 r*(1+r/(compression**2))/(1+r)
expr1 g*(1+g/(compression**2))/(1+g)
expr2 b*(1+b/(compression**2))/(1+b)
name Expression_Corona
xpos -462
ypos -147
addUserKnob {20 User}
addUserKnob {7 compression l "Highlight Compression" R 1 10}
compression 1.5
Dot {
name Dot26
xpos -431
ypos -47
Dot {
name Dot5
xpos -431
ypos 59
Dot {
name Dot17
xpos 29
ypos 59
push $Nb255c280
EXPTool {
mode Stops
red 1.8
green 1.8
blue 1.8
name EXPTool2
xpos -306
ypos -173
Grade {
black {{parent.Grade1_black.r} {parent.Grade1_black.g} {parent.Grade1_black.b} {parent.Grade1_black.a}}
name Grade1
xpos -306
ypos -138
Expression {
temp_name0 tNtD
temp_expr0 toeNum/toeDen
temp_name1 tStD
temp_expr1 toeStr*toeDen
temp_name2 tStN
temp_expr2 toeStr*toeNum
temp_name3 lAlS
temp_expr3 linAngle*linStr
expr0 ((r*(shoulderStr*r+lAlS)+tStN)/(r*(shoulderStr*r+linStr)+tStD))-tNtD
expr1 ((g*(shoulderStr*g+lAlS)+tStN)/(g*(shoulderStr*g+linStr)+tStD))-tNtD
expr2 ((b*(shoulderStr*b+lAlS)+tStN)/(b*(shoulderStr*b+linStr)+tStD))-tNtD
name Expression_Filmic
xpos -306
ypos -95
addUserKnob {7 shoulderStr l "Shoulder Str."}
shoulderStr 0.5
addUserKnob {7 linStr l "Linear Str."}
linStr 0.8
addUserKnob {7 linAngle l "Linear Angle"}
linAngle 0.2
addUserKnob {7 toeStr l "Toe Str."}
toeStr 0.9
addUserKnob {7 toeNum l "Toe Num." R 0 0.1}
toeNum 0.065
addUserKnob {7 toeDen l "Toe Denum."}
toeDen 0.9
addUserKnob {7 whitepoint l "White point" R 0 50}
addUserKnob {7 whitepointExp}
whitepointExp {{((whitepoint*(shoulderStr*whitepoint+linAngle*linStr)+toeStr*toeNum)/(whitepoint*(shoulderStr*whitepoint+linStr)+toeStr*toeDen))-(toeNum/toeDen)}}
Dot {
name Dot22
xpos -275
ypos -52
Dot {
name Dot15
xpos -275
ypos 42
Dot {
name Dot9
xpos 47
ypos 42
push $Naea67450
Dot {
name Dot21
xpos -151
ypos -241
set Nb255b830 [stack 0]
Dot {
name Dot2
xpos -151
ypos -176
set N1a544c40 [stack 0]
Dot {
name Dot3
xpos -151
ypos -134
set N1a544fb0 [stack 0]
Dot {
name Dot20
xpos -151
ypos -105
push $N1a544fb0
push $N1a544c40
Saturation {
saturation 0
name Saturation1
xpos -103
ypos -179
Add {
value 1
name modo_add
xpos -4
ypos -185
Merge2 {
inputs 2
operation divide
Bchannels rgb
name modo_Divide
xpos -4
ypos -137
Merge2 {
inputs 2
operation copy
mix 0.25
name Reinhard_Merge
xpos -4
ypos -108
set Cb20bf900 [stack 0]
Dot {
name Dot8
xpos 69
ypos -53
Dot {
name Dot4
xpos 69
ypos 34
push $Nb255b830
Dot {
name Dot1
xpos 122
ypos -241
Dot {
name Dot12
xpos 122
ypos -174
set N1a602700 [stack 0]
Dot {
name Dot13
xpos 122
ypos -128
set N1a602a70 [stack 0]
Dot {
name Dot18
xpos 122
ypos -85
push $N1a602a70
push $N1a602700
Add {
value 1
name Reinhard_Add
xpos 222
ypos -183
Merge2 {
inputs 2
operation divide
Bchannels rgb
name Reinhard_Divide
xpos 222
ypos -131
clone $Cb20bf900 {
inputs 2
xpos 222
ypos -88
selected false
Dot {
name Dot23
xpos 253
ypos -47
Dot {
name Dot16
xpos 253
ypos 42
Dot {
name Dot7
xpos 90
ypos 42
Switch {
inputs 5
which {{operator}}
name Switch1
xpos 38
ypos 112
addUserKnob {4 operator l Operator M {Reinhard "Exponential luma" Filmic Corona}}
operator Filmic
Clamp {
maximum_enable false
name Clamp1
xpos 38
ypos 153
push $N1a542300
Dot {
name Dot27
xpos -777
ypos -295
Dot {
name Dot6
xpos -777
ypos 218
Merge2 {
inputs 2+1
operation copy
name Merge1
xpos 38
ypos 215
Output {
name Output1
xpos 38
ypos 386
end_group
The gizmo allows for rendering in linear color space and applying reinhard color mapping in Nuke. I can stop saving V-Ray RAW exr’s with baked in color mapping..
Very nice and thanks for sharing! Two notes though:
*) V-Ray squares the burn value before using it
*) The “Corona” and Reinhard mappings are exactly the same formulas eventually, with burn==1/(compression^2) - or compression==(1/b)^0.5 (or in the case of V-Ray itself, burn=1/compression). In the way the script is written, the two modes behave in the same way with respect to highlights.
Is it possible to tweak the code to have the Corona option to be more in line with V-Ray’s method of Reinhard mapping? What would the expression have to change to?
I attempted to update the gizmo to have a V-Ray option instead of Corona. You said the Reinhard and Corona options performed a similar tone mapping, so I just adjusted the tool tips to mention that the Reinhard option is similar to Corona, and now Vray has it’s own option in the drop down. And it looks like it matches exactly in my tests between an image mapped within Vray vs Nuke.
Thanks Vlado!
version 9.0 v1
Group {
name Tonemap
selected true
xpos -21
ypos -156
addUserKnob {41 operator l Operator t "Available operators:\nReinhard (Corona; desaturates highlights)\nExponential luma (modo, Maxwell; saturates highlights)\nFilmic (punchier look, darker shadows; more control over look)\nVray (similar to Reinhard)" T Switch1.operator}
exposure 0
filmic_1 0
Grade1_black 0.005
addUserKnob {6 Grade1_black_panelDropped l "panel dropped state" -STARTLINE +HIDDEN}
addUserKnob {20 Vray l "Vray Controls" n 1}
Vray 0
addUserKnob {41 burn l Burn T Expression_Vray.burn}
BackdropNode {
inputs 0
xpos -663
ypos -224
bdwidth 141
bdheight 196
BackdropNode {
inputs 0
name Filmic
xpos -340
ypos -221
bdwidth 144
bdheight 193
BackdropNode {
inputs 0
name Luma_modo
xpos -171
ypos -212
bdwidth 274
bdheight 190
BackdropNode {
inputs 0
name Notes
note_font_size 25
xpos 582
ypos -307
bdwidth 616
bdheight 512
BackdropNode {
inputs 0
name Reinhard
xpos 116
ypos -215
bdwidth 243
bdheight 191
BackdropNode {
inputs 0
name VRay
xpos -498
ypos -222
bdwidth 151
bdheight 194
Input {
inputs 0
name mask
xpos -462
ypos -344
number 1
Dot {
name Dot11
xpos 499
ypos -341
Dot {
name Dot10
xpos 499
ypos 218
Input {
inputs 0
name img
xpos -581
ypos -344
Dot {
name Dot14
xpos -547
ypos -295
set N4f338800 [stack 0]
EXPTool {
mode Stops
name EXPTool1
xpos -462
ypos -298
Dot {
name Dot19
xpos -216
ypos -295
Dot {
name Dot33
xpos -216
ypos -241
set N4f339c00 [stack 0]
Dot {
name Dot24
xpos -275
ypos -241
set N4f35bc00 [stack 0]
Dot {
name Dot25
xpos -431
ypos -241
set N4f35b800 [stack 0]
Dot {
name Dot28
xpos -612
ypos -241
Dot {
name Dot29
xpos -612
ypos -185
Dot {
name Dot30
xpos -612
ypos -62
Dot {
name Dot31
xpos -612
ypos 80
Dot {
name Dot32
xpos 19
ypos 80
push $N4f35b800
Expression {
expr0 r*(1+r*(burn**2))/(1+r)
expr1 g*(1+g*(burn**2))/(1+g)
expr2 b*(1+b*(burn**2))/(1+b)
name Expression_Vray
selected true
xpos -465
ypos -147
addUserKnob {7 burn l Burn}
burn 0.25
set N4f35a000 [stack 0]
Dot {
name Dot26
xpos -431
ypos -47
Dot {
name Dot5
xpos -431
ypos 59
Dot {
name Dot17
xpos 29
ypos 59
push $N4f35bc00
EXPTool {
mode Stops
red 1.8
green 1.8
blue 1.8
name EXPTool2
xpos -306
ypos -173
Grade {
name Grade1
xpos -306
ypos -138
Expression {
temp_name0 tNtD
temp_name1 tStD
temp_name2 tStN
temp_name3 lAlS
xpos -306
ypos -95
shoulderStr 0.5
linStr 0.8
linAngle 0.2
toeStr 0.9
toeNum 0.065
toeDen 0.9
Dot {
name Dot22
xpos -275
ypos -52
Dot {
name Dot15
xpos -275
ypos 42
Dot {
name Dot9
xpos 47
ypos 42
push $N4f339c00
Dot {
name Dot21
xpos -151
ypos -241
set N502b3000 [stack 0]
Dot {
name Dot2
xpos -151
ypos -176
set N502b2c00 [stack 0]
Dot {
name Dot3
xpos -151
ypos -134
set N502b2800 [stack 0]
Dot {
name Dot20
xpos -151
ypos -105
push $N502b2800
push $N502b2c00
Saturation {
saturation 0
name Saturation1
xpos -103
ypos -179
Add {
value 1
name modo_add
xpos -4
ypos -185
Merge2 {
inputs 2
operation divide
Bchannels rgb
name modo_Divide
xpos -4
ypos -137
Merge2 {
inputs 2
operation copy
mix 0.25
name Reinhard_Merge
xpos -4
ypos -108
set C502d3400 [stack 0]
Dot {
name Dot8
xpos 69
ypos -53
Dot {
name Dot4
xpos 69
ypos 34
push $N502b3000
Dot {
name Dot1
xpos 122
ypos -241
Dot {
name Dot12
xpos 122
ypos -174
set N502d2400 [stack 0]
Dot {
name Dot13
xpos 122
ypos -128
set N502d2000 [stack 0]
Dot {
name Dot18
xpos 122
ypos -85
push $N502d2000
push $N502d2400
Add {
value 1
name Reinhard_Add
xpos 222
ypos -183
Merge2 {
inputs 2
operation divide
Bchannels rgb
xpos 222
ypos -131
clone $C502d3400 {
inputs 2
xpos 222
ypos -88
selected false
Dot {
name Dot23
xpos 256
ypos -47
Dot {
name Dot16
xpos 256
ypos 42
Dot {
name Dot7
xpos 90
ypos 42
Switch {
inputs 5
which {{operator}}
name Switch1
xpos 38
ypos 112
addUserKnob {4 operator l Operator M {Reinhard "Exponential luma" Filmic V-Ray ""}}
operator V-Ray
Clamp {
name Clamp1
xpos 38
ypos 153
push $N4f338800
Dot {
name Dot27
xpos -777
ypos -295
Dot {
name Dot6
xpos -777
ypos 218
Merge2 {
inputs 2+1
operation copy
name Merge1
xpos 38
ypos 215
Output {
name Output1
xpos 38
ypos 386
push $N4f35a000
Viewer {
frame_range 1-100
name Viewer1
xpos -1002
ypos 29
end_group
Looks good. In fact, the “Corona” formula is exactly the one described by Reinhard in his original paper “Photographic Tone Reproduction for Digital Images”. For V-Ray, I modified it a bit as it seemed easier to work with values from 0 to 1 rather than from 0 to infinity.
Vlado, could you please clarify: Is there any downside to applying burn via VFB or comp compared to setting it up in the VRay render settings? Or is it basically the same? I’m thinking about sampling/AA issues…
If you set it in the renderer, it will affect the sampling, yes. This can be very useful when sampling images with bright areas like car headlights, lots of glass that reflects light sources etc. However, you can always set the color mapping mode to “Don’t apply anything” - then the burn will only be used for sampling, but the final output will still be linear. Then you can play with the final burn value in the VFB or in post.
