Transparency in fabric texture
Hi everyone,
I am having problems with the right texture for a fabric material. After adding the transparency, the color is turned a bit grey and the curtain stoff is granulated. How could I get the right texture for a high end rendering?
Thanks in advance
Do you use an image as mask for transparency?
Yes, I have been using an imagen as mask
This image was picture of the week by Enscape Instagram and had the same granulated texture. Does somebody know why this happen? That effect is because of the transparency after adding the mask. Probably it is wrong but how could I get the right transparent texture?
can you share the mask texture ?
you can ask @Joel_Guerra about it he made this project , this is the link for his project :slight_smile:
Práctica de render interior - Showcase - Enscape Community Forum (enscape3d.com)
try to use the Foliage properties to the material
I Think the mask texture must be only black&white, without grey..
Sure.
I’ve been trying with different masks. This are two of them
I also tryed without grey :frowning:
Thanks for the link! I just realized, his curtain had the same texture results I get :confused:
