macroScript LeafConvert category:“John O’Connell Tools”
rollout LeafConvert “AEC Leaf convertor”
fn polyFilter obj = superclassof obj == GeometryClass
Group “Source parameters”
Spinner replaceID “Replace Mat ID” type:#integer range:[-1000,1000,5]
group “Leaf Parameters”
button LeafObject “Define leaf Object(s)” width:200 align:#right filterolyfilter
Spinner Random_scale_min “Random leaf scale min” type:#float range:[-100.0,100.0,0.5]
Spinner Random_scale_max “Random leaf scale max” type:#float range:[-100.0,100.0,0.5]
Spinner Random_rotate “Random leaf rotate” type:#float range:[-360.0,360.0,0.0]
button MakeLeaves “Make Leaves” width:200 align:#right enabled:false
on LeafObject pressed do
if (selection.count == 0) then
messagebox “Please select an object to use as a leaf”
else if (selection.count == 1) then
leafobject.text = $.name
global copy_obj = selection as array
makeleaves.enabled = true
LeafObject.enabled = false
else
leafobject.text = (“There are " + selection.count as string + " Leaf objects”)
on makeleaves pressed do
the_sel = selection as array
if (the_sel.count == 0) then
messagebox “Please select an object to replace leaves on”
) else (
mat_id = replaceID.value
for o = 1 to the_sel.count do
try(convertToPoly the_sel)catch()
face_count = getnumfaces the_sel
print face_count
face_array = #()
-- Get faces with the specified mat id
for i = 1 to face_count do
if (polyop.getfaceMatId the_sel i == mat_id) then
append face_array i
copy_obj_mesh = editable_mesh()
copy_obj_mesh.name = (the_sel.name + “_leaves”)
copy_obj_mesh.pos = the_sel.pos
disableSceneRedraw()
-- Begin progress bar
progressStart “Making leaves”
escapeEnable = false
itemnum = face_count
curitem = 0
for f = 1 to face_array.count do
curitem += 1
the_pos = polyop.getfacecenter the_sel (face_array)
the_dir = polyop.getfacenormal the_sel (face_array)
leaf = random 1 copy_obj.count
print (leaf)
leaf_obj = copy_obj[(random 1 copy_obj.count)]
the_dist_obj = copy leaf_obj
the_dist_obj.pos = the_pos
the_dist_obj.dir = the_dir
the_dist_obj.scale = the_dist_obj.scale * [(random Random_scale_min.value Random_scale_max.value),(random Random_scale_min.value Random_scale_max.value),(random Random_scale_min.value Random_scale_max.value)]
random_rot = eulerangles (random -Random_rotate.value Random_rotate.value) (random -Random_rotate.value Random_rotate.value) (random -Random_rotate.value Random_rotate.value)
rotate the_dist_obj random_rot
attach copy_obj_mesh the_dist_obj
-- Update progress bar
total_progress = ((curitem as float)/(itemnum as float))*100
gc()
progressUpdate total_progress
progressEnd()
enableSceneRedraw()
completeRedraw()
LeafObject.enabled = true
createdialog LeafConvert width:360
