Turbosmooth and interactive render
There is some strange behaviour with interactive render and turbosmooth, if you set iterations 0 and render int.2 - no result at render, increasing iteration 2 and render int.2 - smooth visible, decrease iteration to 0 and render int. 2 - still visible
There are some known problems with viewport/render display of modifiers. I think the most extreme case is resetting xform.
no, xform do not solve this and geometry it’s just plane with cloth. i mean if you activate iteration once you can’t turn it off, even if you set both iteration to 0, only if i turn off modifier interactive render update geometry
Duplicate: Renderer for architectural visualization - Corona | Chaos
oh, ok then =)
