Is there any chance you guys could have a look at tyFlow again? I understand its very difficult to add motionblur to geometry that changes topology. But when the topology is the same it should be able to load and render a tyFlow particle system. Corona hangs on parsing the scene for no apparent reason. Octane is almost just as picky when it comes to changing topology, but it renders these scenes fine. I would prefer to use Corona.
Ive uploaded a new file through the link you provided.
I really feel this is a typical example where motionblur should have worked. The tyflow configuration has been tailor made for corona acceptance criteria - no change in topology, still it hangs at “Transforming Vertices”.
All particles are simple spheres.
There are no particles birthed / killed during the entire animation (no change in topology)
Particles are scaled to zero instead of killing them - so they are still in the scene, just infinitely small.
All particles are birthed at the same frame (frame 0) (the animation is reverse direction so they are all actually birthed at frame 500, just playback is in reverse).
lol yeah, super beneficial. I don’t know what’s going on in that setup, but it would be pretty wild to have stumbled upon a workaround for motion blur that shouldn’t exist yet.
Ya the problem comes from particles being born over a duration of frames. That book scene has all geo spawned at one frame and never changes its count.
I am too having problems for this for a long time now. Even if I would love to be able to have motion blur within TyFlow and Corona, at least being able to turn off motion blur on selected objects would help a LOT. Because now, you have to turn of geometry motionblur on everything to even be able to render particle animations, or try to set up the scene so that particles are rendered separately, which none is ideal. This has been bugging me for a long time.
In TyFlow there’s support for Render instances, which is supported by V-ray. Maybe Corona can make support for that, since Corona now is part of ChaosGroup?
I agree, it will be great if Corona will support TyFlow motion blur and also, finally, motion blur of topology changing geometry. This is the main things for animation of products, advertising, etc…
