I have the issue all the time. While working with materials at some point the UI is not responding. When I try to change color, nothing happens. I could not even move the color slider.
I can not change any number at all. I have to restart Blender, then it works for a couple of minutes, and then the issue starts happening.
Very annoying issue
Please, Help. I decided to switch from V-Ray for Rhino to V-Ray for Blender, and this issue is not letting me work.
This makes V-Ray for Blender useless to me
For quickest help I think it’d be best you contact support (https://support.chaos.com/hc/en-us/requests/new) as the folks there are literally there to try and troubleshoot things with you.
That said, is this happening when you’re using V-Ray or V-Ray GPU?
I mainly use V-Ray GPU. I thought it could be a conflict with an addon, so I did a clean installation. I deleted all the addons, uninstalled every version of Blender, and removed every Blender folder from my HD.
I also removed V-Ray for Blender. I’m using the recommended GPU drivers (Recommended driver updated to 572.16 Studio driver, and for Quadro cards is R570 U1 (572.16)), and I am still having the issue.
So, basically, when I’m changing material properties, suddenly, the UI stops working. I could not change any number or any color.
I have two RTX A6000 on my machine with window 10. Using the released V-Ray for Blender and Blender 4.4.3
