I’m new to V ray and have managed to render basic interiors with great results, but as soon as I start adding furniture, when I then hit render (even at the lowest Output setting), nothing happens, V Ray just refuses to commence.
Is there a way to lower settings even further so that V ray will render something like a dining room or an office?
This is an image of the place I’m trying to render.
Even when I just leave the computer alone after clicking render it refuses to even start. I’ve had this problem on another model as well, one larger than this.
Obviously its the problem with the ‘furniture’ you are using. Did you import the furniture directly from google warehouse? I have always (everytime) done that and resulted in failure on render. Some said its the problem with materials (since a lot of google warehouse’s model are not meant to be rendered) while others said its the complexity of the scene for the project. Exploding the downloaded furniture and then regroup seems to solve the problems, mostly.
