Hi dear community
I’m testing out the new vray 6 GPU and I found an issue when trying to setup the RTX engine on a slave machine.
On the slave I have an RTX 3080 and the latest vray 60005 downloaded from nightlies.chaos.com.
The new “select rendering devices for vray GPU” UI is pretty simple and I select RTX render engine from the drop-down menu instead CUDA (which is the default engine).
The Log shows: “API Mode was changed to RTX” but if I close and reopen the tool, CUDA returned as if the changes were not saved.
Does anyone experiment the same issue?
Any advice?
Thanks and have a great day
AC
