urgent!!!!! alpha on denoised result
I’m rendering an animation and I’m using the vdenoised tool to denoise the frames; the problem I’m facing is that the result file doesn’t have any alpha information while the original file does.
How can I fix this? any help is greatly appreciated, I’m in a deadline.
Load the original frames and transfer the alpha? what are you using for post?
hi neilg, I’m using after effects; could you explain me how to do that? thanks
i dont use AE but this seems to be the right thing
https://forums.creativecow.net/docs/forums/post.php?forumid=2&postid=933963&univpostid=933963&pview=t
many many thanks! it worked!
but I think, this tool needs to keep the alpha information on the file.
