use camera path
For doing animations where the camera just moves is it recommended to use the camera path option?
When using the camera path option can you still set the irradiance map to render every 10th frame or do you have to render each frame?
and do you have to still pre calculate the light cache before in fly through mode with use camera path on?
and for moving objects when using vraysphere method.
Is using the camera path method faster would you still set the irr map to prepass and render every frame how is this faster compared to not using the camera path method? and would the light cache be set to single frame in this case?
